This is annoying. I have Android 5.1.1 and my Jaybird Freedom 4 was working fine until a little while ago; then it wouldn't stay connected. I thought the headset was dead so I bought a new Jaybird X2. Now I find that the connection turns to crap after a few minutes of use with the new headset. I've also noticed other connections such as in my car drop out. Ive also found my old headset still works ok with my old iPhone4. I'm sure it's a problem with the Sony xperia Z3 compact bluetooth.
Come on Sony. FIX IT
Just a little update, USB firmware reflash/repair with official sony tool completely fixed the BT issue for me on z3c.
Don't know if it makes any difference but I didn't restore anything from google backup after flashing.
Everything now works as it should, phone is very stable and battery life is great.
Unfortunatelly flash/repair didn't fix issue it just made it little better.
Audio still very often cutting out on both Jawbone and Plantronics BT headphones.
