Bluetooth turning on automatically
brendin
Hi there,
I'm having problems with my Bluetooth getting on automatically. I tried to look into the settings but can't find anything pls I need some advice..
Tags (1)
12 REPLIES 12
profile.country.US.title
Qatrium
@brendin
What phone and android version are you using?
brendin
I'm using marshmallow phone experia z2
brendin
No reply...I'm still facing the problem
brendin
Don't know how to change the settings
profile.country.RO.title
_alexdon_
@brendin Can you check if the same occurs in safe mode?
alexdon
YoGem
Leader
I think I know what's going on, does that happen in specific places? Like in a mall?
brendin
It shows the smart band option and throw.. Which keeps on connecting even though I don't use that option
YoGem
Leader
Things are two, you have some apps that are turning on Bluetooth to connect to beacons or you have apps that are trying to connect to a Bluetooth device, like the smartband. If you don't use any smartband try to disable or uninstall any app related to it.
brendin
And wat about throw
