Bluetooth turning on automatically
brendin
Hi there,
I'm having problems with my Bluetooth getting on automatically. I tried to look into the settings but can't find anything pls I need some advice..
Tags (1)
12 REPLIES 12
YoGem
Leader
Throw should not be the culprit, as far as I know Throw works with WiFi, not Bluetooth. On another note, I remember that Google released an update.. Let me check something about it and I'll reply... I just got an idea.
YoGem
Leader
Ok so, you should have an app called Google Settings, open it and check if you have "Nearby" active. That will periodically turn on Bluetooth to search for "beacons"... See screenshot below.
YoGem
Leader
And it's still possible that you have an app installed that turn on Bluetooth to search for beacons, what are beacons? Here you'll find info about them: https://developers.google.com/beacons/
