I'm using an Xperia Z1 compact with sony bridge for mac.
Since few weeks, I can't transfert pictures or movies anymore from Xperia to my mac. It works well before...
Xperia Z1C with Kitkat 4.4.4 and Sony bridge 3.7.1
Any ideas ?
thanks a lot
Hi Gabshow!
I'm very sorry to here you have a problem withe bridge for mac.
Try to update bridge for mac on you computer to a newer version.
If it doesn’t work please contact me again.
Best regards
Fredrik
Thanks, it works ; but I don't understand because I tried this solution couple of weeks and it doesn't work.
Well doesn't matter, thanks again !
Hi Fredrik,
my problem appears again and it is not resolved. I think last time I just was lucky it works once after the update....
any idea please ?
thx for your reading.
Hi Gabshow!
Sorry to hear that it didn't solve your problem.
Can you please send me the error logs so I can
provide them to the development crew.
Here’s how to get error logs from Sony Bridge for Mac:
1. In BfM, hold the "alt" key down while selecting the "Phone" menu. Select "Clear logs" to remove all old logs and get a clean start
2. Reproduce the problem you're having, whether it's connecting the phone, importing photos, doing backup...
3. In BfM, hold the "alt" key down while selecting the ”Xperia” menu. Select "Export logs"
4. On the computers desktop there should now be a file named "SonyBridgeForMacLogs_[date].zip
5. PM that file to me
Thank you very mush for helping.
Best regards
Fredrik
