Settings > apps > all > calendar > clear data > restart your phone > check again
Hi mummybrew,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you able to boot the handset in to safe mode and advise if the calendar works from there?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Let us know how you get on.
have you disable any app? or rooted your phone and removed/uninstall apps/services?
What if you re-install the latest android update
Bridge (for Mac)
