Hi guys new to this sort of thing, is it possible to drag and drop pictures into the pc companion for the sony xperia z1?
I have tried but to no avail....
Could anyone help me please....
It will be easier to do this
connect your phone to a PC > computer > xperia Z1 ? internal storage/SD card > select a folder > drag pictures, music, videos, etc
I did try that and it worked, though it says that the file is unsupported once i looked at it 😞
That doesn't make sense, could you elaborate on the files you are trying to drag/transfer to your phone?
I have taken pics off my old phone and put them on the screen, i then made a folder of them so it was easy to transfer so i tried the drop and drag thing but didn't work.....
really odd, what if you copy paste?
I'll try that and let you know.....
No that hasn't worked either. The pic that i do get is a question mark, and its says unsupported file
try a different USB port
Could i possibly do it with the NFC???
