Camera problems
Alcan18
Camera problems
Once i start taking pictures, after the fourth or fifth photo the camera stops working. And if i open de photo album it doesnt work either. What should i do? Thanks!!
Tags (1)
3 REPLIES 3
profile.country.PH.title
MarlonUk1
does this problem appear on safe mode?
try to clear camera app data.
settings>apps>camera>clear data , restart your device
Alcan18
Thanks!! But still doing the same misfunction
Didrik
Enthusiast
Hi @Alcan18,
Did you still experience this while your device was rebooted to safe mode?
Is there any change whether you store your photos on the internal storage or on an SD-card? To change this, open the Camera app > Press the cogwheel > More > Data storage. If not, I'd suggest you perform a software repair using Xperia Companion.
