Cannot receive calls when GPRS is on
Not applicable
I have a X2 WM6.5. When I connecting to GPRS I cant receive calls. Can you helpl me to solve it?
2 REPLIES 2
Not applicable
There used to be a problem on very old phones where if your using a 2G network (which GPRS is) and you have an active data stream calls would be diverted, this was because the system only allows either a call or data. In newer phones (X2 included) the phone will hold the data stream when you make or recieve a call. You shouldn't have any problems with missed calls or not being able to recieve them while a data call is active. Could be a faulty handset, or you could try re-installing the latest firmware, though I can't see that being the issue. Either that or your network has a problem.
Not applicable
Hi!
If nothing else works, try to get a new SIM card from your mobile operator.
Rgds
