Charging time?
intz3007
Charging time?
My device is just 3 days old. I'm happy that the battery lasted almost 2 days with normal use, but I've noticed the battery isn't charging as fast as first time.. Is there a problem? I already have a low ringtone problem.. Hope I don't have another issue.. Guys pls advise..
Tags (1)
4 REPLIES 4
profile.country.RO.title
_alexdon_
@intz3007 What adapter are you using? Also, do you use the device while charging?
alexdon
intz3007
Stock adapter that came with box. Not using device while charging.
_alexdon_
Can you download the app called ampere from play store and check what current your device is getting?
alexdon
Jake-SonyXperia
Champion
Hi intz3007,
Can you please advise of the timeframe for low battery to full charge, this will advise us if the charge time is normal or not.
