com.sonyericsson.crashmonitor stopped
adamcs820
PLEASE HELP!
I just bought the Sony Xperia C3 ... and when I changed the wallpaper,  the screen just keep on and off on and off. After a few minutes later, that message comes in " com.sonyericsson.crashmonitor stopped working" ... What can I do??
Million thanks!
1 REPLY 1
Thommo
Try performing a system repair as this will often fix issues - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
