Sw2 keeps connecting and disconnecting
Me23
Different certificates of Host App and Smart Connect. Host App cannot start.
I get this message trying to use the Sony Smartwatch 2 on my Samsung Galaxy S4 and think it may be a problem of interaction between the Smart Connect and the SmartWatch 2 application.
Is it not possible to integrated the 'Open/Connect sw button'  in the sw2 app to solve the problem and need only one app instead of two to connect?
As of yet I have not solution. Your help is appreciated.
1 REPLY 1
Thommo
The installed apps are not the means of connecting merely a way to control apps and Smart connect is a way of listing what devices are connected and hosts the shortcut to the hidden app for said device
