E3 memory transfer to sd card problem
briangoo1974
Hi I've just bought a E3 but the memory is getting filled to quickly and apps like fb & YouTube can't be moved to sd card. Will rooting the phone let me do this
8 REPLIES 8
Thommo
Can't be sure but if it does then any apps you do transfer may not be guaranteed to work afterwards
briangoo1974
Great not phones these days use fb and YouTube surely anyone with 1/2 a brain would have foreseen this ๐Ÿ˜ž๐Ÿ˜ž๐Ÿ˜ž
Thommo
No idea what you are trying to say
briangoo1974
I'm saying that you should be able to transfer data to the sd card on all apps as fb & YouTube builds up loads of data on your phone. Thus filling internal memory far too quickly ๐Ÿ˜ž๐Ÿ˜ž๐Ÿ˜ž
Thommo
I'm just a member like you so have no control over these type of things - For grievances you need to contact Xperia care via email - http://www.sonymobile.com/global-en/support/contact-us/
briangoo1974
Plz I know I'm not having a go at you. It's just a bit maddening that the 2 biggest apps aren't transferable ๐Ÿ˜ž๐Ÿ˜ž
Mark4
Hey i bought an E3 as well and i installed Navigon. The app goes to the sd like normal but while the maps should go there as well like in my old phone they don't.Instead it says that in the chosen place to be installed is no memory anymore (phone's memory). There is space in another place (sd card).And while i press yes to confirm it it says error occured. Is really irritating cause it eats all my space.
Hey how can you root the phone cause i am having the same problems and is this going to affect guarantee?
briangoo1974
Yes but will root allow you to move such apps to memory card
