Elm phone problem
Not applicable
Elm phone problem
A grey box headed 'Today' has suddenly appeared on screen and will not go - any help would be appreciated
thanks
5 REPLIES 5
DeGraaff
Contributor
That's the Calendar widget, it shows your upcoming plans. You can disable it in the home screen by press 'up' on the direction pad, then press the left soft key to manage your widgets, and then press the 'center' key to hide the Calendar widget.
Not applicable
Is there a quick way to get back to the home screen when you are on the internet or on other pages, as I have to keep pressing the back button to get there?
DeGraaff
Contributor
Yes, press the "power/end call" button. That should take you directly to the homescreen. The same button also functions as a shortcut key to minimize or forcefully close any java application.
Not applicable
Thanks, simply really why did I not think of that.  But I have only had the phone two weeks and just learning how to use it, thanks for your help.:smileyhappy:
Not applicable
Hi. 'today' box nullified. Thanks !
