wi-fi
Not applicable
wi-fi
Dear SE users hello, i've a problem with my aino when i connect it to wi-fi networks(open networks like MacCdonald's),it connects with networks but don't browse anything and show the err notification.please guide me how to deal with this problem
4 REPLIES 4
Martha-
Contributor
What error do you get, exactly?
Not applicable
The network is connected,signal strength is also good but when i open the internet icon in phone and want to browse any web site like sonyericsson,it waits for a long time and then show an error saying "communication error.Try again or contact your provider for service"
Mam i also have written to you about the problem to connect internet of my computer to my aino
Not applicable
When you go to Settings, connectivity, Internet Settings...do you have 'allow local connections' checked as 'yes'?...if not, that is most likely it...I am assuming you do not have a data plan, which is why you would get that error...the phone is still trying to connect using data coverage via your contract provider, and not your wifi connection...just having a wifi connection does not override that connection setting if it is checked as 'no'...
checking yes should allow the browser to default to the wifi connection when available...but you will need to do the same thing in the options of each application you plan to use also...
Not applicable
thanks a lot for your help.
yeah it's already checked yes,still it's the same.If have some other openion then can tell me.
