I see this occasionally.
The card hasn't actually been removed, right?
I have some apps on my home screen that are stored on SD card and sometimes they have an icon next to them to indicate the SD card has been removed.
I just remove and re-insert the card and it resets.
Hi there,
I have noticed that since the last firmware update my SD card ejects itself occasionally. It then reinstalls itself.
This is very annoying as it tends to happen whilst I'm using the Music app and playing music.
Any suggestions on what is happening and how I can prevent it from happening again?
