Hi, i have an Xperia Z and my GPS doesn't work, i tried to uninstall maps and reinstall but no change of situation, location services are active...
When i open navigation it keeps saying "searching for gps" and i waited like an hour but nothing...
Anyone has any solutions for this problem? Thanks!
Are you outside or indoors?
Make sure you have activated Google's place service under settings > location services.
If you are outside and Google's place service is active and you still experience problem I suggest that you go into to the service menu, press *#*#7378423#*#* in the phone dialer. Go to service tests > GPS > purge assistance data. Restart phone and try again. Normally it takes a while for the GPS to find your position after you have purge assistance data so have a little patience when you try again. Also make sure to be outside.
Thanks a lot, i entered the service menu and i purged assistance data and then it worked xD.
Do you know when the update to 4.2 will come to Romania? Orange is my network provider.
Thanks a lot! xD
Thnaks, Alexander - you've solved my problem! Pity Sony don't tell you this. Is there any way of doign this without having to remember this phone number?
please help me
i have Xperia ZL and having a problem for GPS is not working.
always looking waiting for location ...
Just registered to say this:
*#*#7378423#*#* translates to *#*#SERVICE#*#*
Much easier to remember!
