In-car bluetooth issue
karlhinze
Hi. I'm having problems using the bluetooth in my car to make calls using my Xperia Z1. I can pair the devices, but when I enter a phone number and press Dial, it just says Dialling Failed. Also, when someone calls me, It shows on screen and gives me the option to Answer or Decline. However, when I choose Answer, nothing happens and the phone keeps on ringing. My previous Android phone worked fine, as does an IPhone 5. Anyone got any ideas?
Thanks,
Karl
11 REPLIES 11
karlhinze
Edit: My car is a 2012 Vauxhall Meriva.
nalab1
If you are running any software release higher than 14.1.G.2.257 (Android 4.2.2) then IT WILL NOT WORK....
 AS SONY/GOOGLE HAVE COMPLETELY SCREWED UP THE BLUETOOTH STACK ON ANDROID VERSION 4.3 (.290 and .136 firmware) AND FROM WHAT I CAN ASCERTAIN,  4.4...
The only way to get your phone to work properly is to "downgrade" back to 4.2.2 - see here -
XDA
I have flashed my Z1 back to 4.2.2 and everything works fine on my Insignia with a Navi800 audio system. Make a backup first!!!!
karlhinze
Thanks for your speedy replies people. So it's not just me then! Fortunately I've not had this phone long so there's not much to back up. I'll give that a go...
nalab1
I would.. Let me know how you get on...
Nick32
Just for the record, I have had that problem with 4.2.2 as well. Whilst it may not be fixed by 4.3 that didn't create the problem I don't think.
My Xperia has had the bluetooth connectivity issue since Sept 2013 (whatever version of Android that was!).
Regards
nalab1
It was shipped with 4.2.2... What car/audio system have you got?
Nick32
Mercedes Benz audio - only a year old.
Tags (1)
Nick32
4.2.2 is claimed as compatible but asd I said, I have always had this problem with connectivity that other compatible phones don;t have.
karlhinze
Nalab, thanks for your help so far.
However, I'm pulling my heair out over this. I just don't get it.
I'm on a mac, which probably doesn't help. But It's asking me to turn it off and press the back button... There is no back button apart from the touch screen when the phone is on. I've read that the equivalent is to press the volume down button. But nothing happens when I do that.
I'm tempted to throw this useless pile of rubbish out of the window and go back to my age-old Samsung Galaxy Mini. My heart sank further when you said that even 4.4 pronbably won't fix it.
Can you help?!
