uploading documents
SirDarlon
uploading documents
I'm having issues uploading my documents, specifically my c.v. To websites. Neither drive nor office suite will let me do so. Is this a known issue, or is it a bug? And how can I fix it?
6 REPLIES 6
Uliwooly
Uninstall and reinstall the app(s) and try again
SirDarlon
Already tried before posting. I've tried turning it off and on again too.
Uliwooly
Do you have any taskiller and/or antivirus that might be blocking this? have you disabled background data on any of the apps?
SirDarlon
I've checked, no this is not the case uliwooly. It's driving me nuts to be honest. If I upload something the filename will appear for a split second before disappearing again. I'm at a loss.
ron_xperia_z1
Have you checked if your file was uploaded to the site? Sometimes I post something but does not continue, then when I check the site, it's already posted there. Or sometimes I am asked to log in to a particular site to post something.
SirDarlon
The site said there was no file and I was therefore unable to continue. I was logged in. I checked multiple sites, same problem
