Issue while making or receiving calls
Dodo1515
Every time l receive or make a call,phone goes on quick setting,switch to mute,wi-fi off,or worst airplane mode which automatically hand up the call!!tried everything..repairing,reset factory.tested sensor with diagnostic and it's working.is there another way to lock the phone while making calls?any help please ???is it a bug from 4.4.4,because l did not have this issue with 4.4.2!
10 REPLIES 10
profile.country.RO.title
_alexdon_
So you press the power button? You might have enabled power button ends call.
alexdon
dandy63
Leader
Does this happen when you place the phone to your face/ear to answer the call & the contact with the screen opens various apps etc?
Dodo1515
Yes,it starts by opening quick settings,then various apps.
Uliwooly
Dodo1515
Sorry but What do you meant by enabled power button end call??
Dodo1515
OK,l will try it on safe mode,then keep you update.thanks.
_alexdon_
There is an option in accesibility called like that.
alexdon
Dodo1515
found it but power button end call is off.
_alexdon_
In this case,boot in safe mode and keep us updated.
alexdon
