K810i - SMS backup
Non applicabile
K810i - SMS backup
I have a K810i and would like to take a backup of my text SMSes.
I have searched for this topic in these forums and it seems that there does not seem to be a way to do so.
However, after using PC Suite, I am quite confused. Limiting ourselves to PC Suite for now, here are my doubts:
1.  Using PC Suite, is there any way to create a backup of my text SMS?
2.  Can the backups be stored in text format so that I can just browse through them like text files? I hate to depend on PC Suite just for viewing some text.
3.  Can I restore this backup in case the SMSes on my phone are lost by accident?
4.  What does the PC Suite Archive do? I copied my SMSes from the phone to a new archive and they are visible even when the phone has been disconnected from the PC.
I can see that PC Suite creates a bunch of text files in random order for these archived SMSes.
Thanks for your help !
3 RISPOSTE 3
Non applicabile
Never mind.
Used MyPhoneExplorer and exported the SMSes to HTML format.
Non applicabile
you cannot copy back to the phone your messages (you can, but it's lots of work - hacking)
you can save your messages also  in SE pc suite by selecting print in the message archive of your phone, and then print to file (.mdi extension)
Non applicabile
Thanks Lucifer. I will give the "print" option a try.
