Hello
You must use 3rd party apps
I use illumination bar and it provides good control over illumination bar
The blink ratio of a SMS received or a text on Whatsapp is different over illumination bar. This doesn't mean there is any problem.
@tj on older firmware by receiveing sms led bar start to glow in glow out by fully brighen bar if stamania was on...if stamania is off lights works just like now
@misscaro
All of us face that...its update issue..
And if you want to receive light for all notification you must turn stamania mode off...but then lights just blink untile you turn the screen on...by 3rd party apps you can have that old beauty led bar and receive light for other apps even stamania is on or off
Yes..thats right
