Light effects not working
MissCaro
Hi, I have just updated the software on my Sony SP and the light effects won't work properly, I.e. When I have an unread text message, it flashes briefly, but doesn't stay illuminated. Anyone know how to fix this?
16 REPLIES 16
MissCaro
I meant to say doesn't blink again in my previous post
robsonkxd
Try to factory reset it and before doing that remember to back up your data. I hope this will help.
robsonkxd
It used to do the same but after I did the factory reset it's now working fine.
MissCaro
Thanks. I'll try a factory reset and see how that goes. Can someone suggest the best way to back up my data before doing a factory reset. Will a factory reset wipe what I have saved on my memory card?
Tejinder
Use PC Companion for resetting your device, it will give you the option to backup your data.
robsonkxd
You can also use the back up and restore application on your phone.
robsonkxd
No it'll not wipe the data on the Memory Card.
