Macro-Mode for barcode-scanning possible?
tipotypo
Hi there,
from what I read in this and other forums there is no way to decently do a barcode scan with the TIPO because of its camera quality.
I was able to work with the build-in NEO scanner on QR codes but it seems that most of the problem with a regular barcode comes from a blurry focus on a closeup rather than from a resolution problem.
Is there any way to establish some kind of macro mode for the built in camera? I had done way better macro pictures with older SONY handy cams, but they always had the possibilty for a macro mode. Is this purely a question of unlocking this feature?
And: is there an app around that unleashes this feature in the camera?
Yours,
Ray
4 REPLIES 4
Johan
Master
I'm not aware of any app for this unfortunately but I will pass on your feedback about this. But I can't promise any changes.
Thanks for your feedback.
makaveiljojo
Is that build-in NEO scanner you mentioned working only on QR codes? I'm having a barcode reader on my tablet to read code 128  but at times it fails to scan. No idea if the resplution issue or something else.
profile.country.RO.title
_alexdon_
Neo reader works,you have to capture the whole code.
alexdon
makaveiljojo
Cool. Thanks
