mail client settings for Sony Z2 tablet
pilotbroth
Tried to use standard mail client. However incoming mails are ok and are being downloaded. As for outgoing mails...here there is no synchronization with other devices, if You send mail there, it will appear in outgoing folder, if some message is sent from other device, it doesn't appear in this standard client application. The problem is only with the outgoing folder.How to fix?
Thanks
1 REPLY 1
Jake-SonyXperia
Champion
Hi pilotbroth,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you running a POP3 account? as POP3 only really shows a copy of what is in the inbox, outgoing would only show if say you used Exchange or IMAP4 based accounts.
