missing clock widget after phone restart
martinmrmus
Contributor
Hi. After restarting my Z3 phone clock widget (preinstalled) vanish from homescreen and it isn't available from widget pickery What should I do to get them back?
6 REPLIES 6
Uliwooly
Settings > apps > all > scroll to the bottom > look if you have disable any app
martinmrmus
Contributor
I have disabled apps, but none is related to clock widget. Disabled e.g.: google drive, dynamic wallpapers, evernote, chrome... But nothing with clock. It worked fine till my first phone restart (11 days since buying)
Uliwooly
enable all the apps and check again.
martinmrmus
Contributor
Didn't helped. But I uninstall updates from clock widget app and they've showed up again. But now, how can I get update of clock widget back? Update center found nothing.
Uliwooly
restart your phone and check again
martinmrmus
Contributor
What is the built no. of updated clock widget? Mine is 4.0.A.0.7 (for Z3 kitkat 4.4.4)
