There is no option to wake up the phone by double tapping on the screen like in z3 and other phones.
Can you add this? It's totally annoing to wake up the phone by pressing the small side button.
You should forward this to sony developers:
http://developer.sonymobile.com/about/how-do-i-get-in-contact/
Thanks!
I did forward this to them, hope to get the solution fast.
Is there other ways to wake up the phone?
Sorry,you could look for 3rd party apps but not sure how much you can rely on those.
I researched them - they are all fake.
They are just turning the brightness to zero, emulating that the phone is sleeping.
In this case,wait for the developers to reply. Perhaps you can try to contact xperia care too:
http://www.sonymobile.com/global-en/support/contact-us/
The developers wrote me that they'll look at the issue, hope to get the update soon.
Hope you will be pleased with their answer.
Hello. Any updates?
