There is no option to wake up the phone by double tapping on the screen like in z3 and other phones.
Can you add this? It's totally annoing to wake up the phone by pressing the small side button.
No, I'm still waiting.
any updates yet? i'm also looking for a solution to wake up phone easy ...
Agree! very annoing!
I tried to find an app to wake up screen by tap but I failed.
did you find good answer for us?
I still use this (from my old phone now with M4) tap tap app
this is not "TAP to WAKE", it just seems you are "tapping" your phone but actually hovering on the light sensor of our phone.
hope this helps.
This is so annoying, missing one of the most essential functions. It is quite hard to press the power button about a hundred times a day... I hope it gets resolved in next software updates.
Hi I found an app in app store called Screen Lock Unlock for my M4 aqua and it works by passing your hand across the screen 2 to 3 times and it wakes the phone.
