Hi subrahmanyam007,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Are you able to advise where the content is loaded, is this on the internal storage or the SD card?
Sorry you mean both have content loaded on to them?
That seems that the SD card it's corrupted, you could unmount the SD card > turn off the phone > remove the SD card > turn on the phone > check if you can access anything on the internal storage
Which apps are you using to check your photos and movies?
