Is it possible to sync the phone over wifi? I would like the phone to connect to my computer and update automatically over my home wifi network rather than connect physically with a USB cable.
Settings > about phone > software update, if you want to sync something else check the playstore
Sorry for not being clearer in my initial post. I particularly meant sync with the PC using PC Companion. The options for bluetooth and wireless are available but I can't get them to work with the PC. Is this possible with the Xperia Z1?
We can sync over wifi throug PC Companion
