Problem with battery life
Marwa95
Hello ,
I have a problem with my phone is battery (sony xperia m4) when i leave it about 30% and going to sleep then after 8 hours when i wake up and checking my mobile i find the battery empty
What can i do in this case?
Thanks Slightly_smiling_Face
Tags (1)
4 REPLIES 4
Uliwooly
@Marwa95
We'll need more info to better assist you
charge the phone 100% use it as you normally would then once the battery reaches 10%
settings > power management > battery > take screenshots of:
1. the list
2. tap on the graph and take a screenshot
3. back > tap on the top 4 items on the list > take a screenshot of each
Then charge the phone 100% > boot in >>> safe mode take the same screenshots once the battery drains to 10%
post them all here or upload the screenshots to box or dropbox or google drive or etc and post the link
valyo_bg
In Marshmallow battery life is better than on lollipop. So it's a good idea to update your phone.
Seems that poor battery life is because of non stop working GPS - it use more current and this is normal. On both screenshots for safe mode and normal GPS work most of time. So turn off GPS and try again, I'm sure that battery life will increase dramatically.
Uliwooly
@Marwa95
The WiFi it's on all the time, that's draining your battery quite fast. Also, I think the list it's not full, there are missing percentages but it's the WiFi.
