Problems with Smartband SWR10
idemnias
Buenos dias, decir ante todo que el movil va de lujo.
Y de hecho tenemos dos, yo y mi pareja.
Pero tengo un problema, la smartband de mi pareja va bien, pero la mia se desconecta a cada rato, se puede desconectar 6 veces en una hora como en casi dos horas no se desconecta.
Necesito soluciones aunque lo mas probable es que lo devuelva para que me dean otra.
P.D. Probado bateria cargada completamente del movil y de la smartband. Movil reiniciado a mayores por si habia tenido algun problema el movil.
Se desconecta con el movil a menos de un metro de mi muñeca.
Good morning, say at the outset that the phone is luxury.
And in fact we have two, me and my partner.
But I have a problem, the SmartBand my partner is fine, but mine is disconnected all the time, you can disconnect 6 times in one hour in almost two hours is not disconnected.
I need solutions but chances are that you return to me dean other.
P.D Tested fully charged battery of mobile and SmartBand. Mobile restarted at higher if the problem had been mobile.
It disconnects the phone less than a meter from my wrist.
3 REPLIES 3
dandy63
Leader
Hi, have you checked/read the section on Smartwear on the Forum site........possible solution there :smileysmileywink:
Uliwooly
Do you have stamina mode on?
idemnias
Modo off
