My SP which I've had for a few months now, has recently stopped charging properly, doesn't matter what I do, it will only charge when it wants to, I've even tried different cables, if the factory restore doesn't work, then I'll have to take it back to the store I got it on contract from.
Anytime.Did you check for the update?Do it,it should be available soon for you.
I check everyday and the problem is still occuring.
Take your phone to closest service,they could update it there and fix your issue.
My nearest sony center is in Portsmouth 20 miles away, also I've got my phone charging now, just hope it will keep charging until I can take it somewhere for them to find the problem if it happens again.
Ok,keep us updated.
Will do.
Unplugged it and plugged it back in, the problem is still persisting, will take it to the store I got it from to see if they can find out what's wrong with it but it's defnitely something wrong with the micro USB port on the device itself as I get the same problem with any cable I try, even if it's plugged into my pc, even data transfer is iffy.
Yeah,it is best to take it somewhere authorized.
