Prolems charging SP
Gari_Ferret
Prolems charging SP
My SP which I've had for a few months now, has recently stopped charging properly, doesn't matter what I do, it will only charge when it wants to, I've even tried different cables, if the factory restore doesn't work, then I'll have to take it back to the store I got it on contract from.
16 REPLIES 16
profile.country.RO.title
_alexdon_
Have you tried a software repair via sony update service?
alexdon
Gari_Ferret
I will try that when I can get the backup and restore app to work, think it has something to do with the micro USB port on the phone though as wiggling it in the socket makes it start charging, as does holding it in a certain position, had a similar problem with the old X8.
_alexdon_
Use Sony pc companion or myphone explorer to backup your contacts,messages,settings etc.For the media files,it is better to manually copy them to a PC.
alexdon
Gari_Ferret
I've got the app for it working, it won't back anything up while it's downloading app data.
_alexdon_
Ok,be careful what you do.
alexdon
Gari_Ferret
Yeah, just backing everything up onto the SD card...
Takes quite a while.
_alexdon_
Keep us updated.
alexdon
Gari_Ferret
Will do.
Gari_Ferret
Reinstalling the firmware using update service worked as far as I can tell, thank you, now to wait for the 4.3 update.
