Prolems charging SP
Gari_Ferret
Prolems charging SP
My SP which I've had for a few months now, has recently stopped charging properly, doesn't matter what I do, it will only charge when it wants to, I've even tried different cables, if the factory restore doesn't work, then I'll have to take it back to the store I got it on contract from.
16 REPLIES 16
profile.country.RO.title
_alexdon_
Anytime.Did you check for the update?Do it,it should be available soon for you.
alexdon
Gari_Ferret
I check everyday and the problem is still occuring.
_alexdon_
Take your phone to closest service,they could update it there and fix your issue.
alexdon
Gari_Ferret
My nearest sony center is in Portsmouth 20 miles away, also I've got my phone charging now, just hope it will keep charging until I can take it somewhere for them to find the problem if it happens again.
_alexdon_
Ok,keep us updated.
alexdon
Gari_Ferret
Will do.
Unplugged it and plugged it back in, the problem is still persisting, will take it to the store I got it from to see if they can find out what's wrong with it but it's defnitely something wrong with the micro USB port on the device itself as I get the same problem with any cable I try, even if it's plugged into my pc, even data transfer is iffy.
_alexdon_
Yeah,it is best to take it somewhere authorized.
alexdon
