Random audio problems
elaine
Hi everyone,
I've been noticing some randon audio issues with my Z1, and was hoping for some assistance/advice.
1. Audio when playing video (either in the movie app or on youtube app as example) stops working randomly.  The only solution is to switch off the phone, and turn it back on.
2. I have a daily alarm that is set--randomly the audio portion of the alarm oftentimes does not work when the alarm goes off.  It just vibrates only.  Only solution is to switch off and on the phone.
I've noticed that both problems happens quite often; and I can't pin point if something specific "triggers" the issue.  I've become so paranoid that my alarm won't work properly that I'm checking it every night before I go to bed and testing it all the time.
Thoughts?
Thanks!
1 REPLY 1
jflipa83
My wife has the same problem. Did a factory reset but still no good. I also noticed that when it happens the video playback is fast.
Thanks
Joe
