Hello,
my Xperia Z1 has started to face battery drain problemas a month ago.
It randomly goes to 0% and it turn off even if it was with an high remaining porcentage.
Some times I need to connect it to the battery charge to be able to turn it on and it starts to optimize the apps like after a software upgrade.
What can I do? Does it mean that my battery is dead and I need to replace it? My phone is 2.5 years old.
I attached some screen captures to explain the problem:
Thank you in advance for your help,
Pietro.
Hi Pietro_B,
Welcome to the community,
From what I have seen this can be related to software over hardware. I would suggest backing up your device and then using Xperia Companion to repair the handsets software.
I have faced this problem twice. The first time it was solved after a factory reset. THde second time nothing could solve it and I send to my local Sony repair center. There they diagnosed a battery problem (as I had thought) and they replaced the battery
