Hi. I am looking for some advice with regards to how I receive calls on my Xperia X10i. Basically, the story goes as follows...normally when I receive a call I have to do that swipe thing to accept the call, however, at very random times instead of the swipe I get the option of pressing 'Accept Call' or 'Decline Call' which are displayed on the lower part of the screen side-by-side. Now, to be perfectly honest I actually prefer the latter option but do not know why it is so random. To be clear, I have never updated my phone since I got it and I have searched the settings but not been able to locate anything which would explain this.
Any assistance would be much appreciated.
Kind regards
Scott
Okay, this should be a simple one.
When your phone is locked when the call comes in, all you need to do is swipe the screen to answer. But if your screen is unlock at the point the call comes in, you will be given a choice to "answer" or "deny".
LOL that was a "simple" one...I can't believe that I never figured it out
Thank you for your quick response.
Kind regards
Scott
I was just "passing by". You're most welcome.
