screen auto turn failure
reemus
My screen doesn't turn automatically (I think I happens when charger in on) then I have to restart.
9 REPLIES 9
profile.country.RO.title
_alexdon_
So when you are charging the screen doesn't light up?
alexdon
reemus
when I hold my telephone horizontal the image doesn't turn (auto turn on)
My screen also isn't always compleet black on standby... I don't no if that is related.
Sometime's I can't get my screen on. ( I can get the volume up/down sound)
reemus
Auto turn failure. When my phone is charging ( I think)
_alexdon_
The screen isn't supposed to rotate unless you are on a magnetic dock or cable.
alexdon
reemus
Sorry my English isn't that good ;-). Normally when I turn my phone from vertical to horizontal my screen turns. ( when auto turn is on). My problem is when I turn the function auto rotate on. After some time it doesn't rotate anymore. (whit the auto rotate function on) when I want to look a movie (on fb) it's very small.
Greetings
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
reemus
Thanks!
Uliwooly
Anytime
