Screen rotation doesn't work, only work in safe mode.
nasnolimit
Had try so many time to restart the phone, then it work for 10 min only. Had run in safe mode for few times and it only work in safe mode, so I deleted a lot of apps, almost all apps are gone but still didn't work in normal mode. Please help...
1 REPLY 1
Didrik
Enthusiast
Hi @nasnolimit,
If this works while your device is rebooted to safe mode then it sounds like this is caused by one of your downloaded apps. Have you tried updating all your downloaded apps? If that didn't help you may unfortunately have to uninstall them, one by one, in order to try and find the culprit. A tip is starting with the ones most recently installed.
