sd card not working
Polky
sd card not working
Have been using an SD card successfully for the last year or so but all of a sudden it no longer works. Gone into settinings/storage and there is nothing there. Have tried removing and replacing but no good ??? Any ideas please.
1 REPLY 1
Jake-SonyXperia
Champion
Hi Polky,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you able to insert the SD to a PC? if you can and the issue continues, then unfortunately there is not much you can do.
