Have been using an SD card successfully for the last year or so but all of a sudden it no longer works. Gone into settinings/storage and there is nothing there. Have tried removing and replacing but no good ??? Any ideas please.
Hi Polky,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you able to insert the SD to a PC? if you can and the issue continues, then unfortunately there is not much you can do.
