My software was upgraded to 4.3 and I noticed severe system slowdown. Is there anything I can do to resolve, or you? Btw, I'm from Brazil.
Let the phone adapt for some time,make sure to restart it regularly.It should improve.
What does that mean, it is a phone not a human or at least A.I. to be able to adapt, my device also works much worse after the update, I've noticed some improvements in battery life, but every app and menu I choose takes time to load, not to mention Chrome and mail where I need to wait around 10 seconds or more just to get the keyboard up....
After a major software update,the battery and the operating system need some time until they work at full capacity(that is normal as it adapts to new conditions).You can try to repair via sony update service:
http://www.sonymobile.com/gb/tools/update-service/
Alexdon is right...let your phone to adapt for now conditions...for me at first I have some speed problem(I gone after reset to factory)and overheating and battry drain..but after 2-3 days all of probpems are gone..now phone works perfect without any problem
I'm brazilian too, and I also have some problems after updating to 4.3.
I don't know what they have done, but they realy found a way to turn it into a paper weight!
I don't believe that it is caused by the fact that it's getting "used" to the new system. Mine is llikee, two weeks this way.
The old version was TIMES better than now.
It's taking 30s to open, Whatsapp, Facebook is crashing and it's hard to even answer a call...
What can I say...
Thanks, Sony...
