Hi, I have a vivaz vodafone with sim 128kb of tim, I wanted to know why after 20 sms I received the sms out "sms sim card memory full" and I have to manually clear the sms but the problem is not resolved and I have the desktop icon message that is flashing continuously.
The sim is very large as the old cell line had more than 1200 sms.
How can you avoid this problem?
Thanks
Gaetano
Hi Gaetano,
It sounds like the SMS messages may have been stored on the phone memory and not the SIM card, itself. I see that in the settings, the default number of messages is 20. Also, you can change the location of the message memory (Memory in use) from the memory card to the phone, and when you change the location, the phone asks if you want to copy all messages to the new message memory.
So, in Messaging select Options and then Settings. In Settings, scroll down and tap Other. This is where you will find the option to change the Number of saved messages (up to 999) and the Memory in use.
I hope this helps!
Hello Martha,
I have done all these settings but the problem is unresolved and the icon sms on your desktop that flashes ever.
Thanks
Gaetano
Same problem on Vivaz Pro Vodafone with Wind sim card, I think it's a firmware problem and Martha's suggestion isn't helpful maybe because we're talking of receaved sms, not sent sms.
Waiting for some response.
