Soft charging support
Xjoshualaw29
Hello,
Can Sony make an update for the Z5 series to put soft charging like the beta series to increase the battery life last longer for the older models? Like the latest X series they have Qnovo charging which help to make the battery life increase and maybe can it be done for the Z5 series?
6 REPLIES 6
Uliwooly
@Xjoshualaw29
If this is implemented now, I doubt it'll make much difference for a phone that has been used for several charging cycles.
Xjoshualaw29
@uliwooly
Yes, it will. I just want to see the software developer reply on my suggestion to this update. I hope that it'll happen.
Uliwooly
@Xjoshualaw29
Got it, this is a user based forum, it will be wise to send your feedback to Sony >>> Local support
adamlee2014
Contributor
Soft charging will be available in the next update.. It's already rolling out in Japan 😃
Uliwooly
@92
Thanks for the heads up
adamlee2014
Contributor
KDDI is September 1, has started a software update of Sony Mobile-made Android smartphone "Xperia Z5 SOV32". In this update, as well as NTT DoCoMo version, charging optimization features to maintain the battery life longer will be added. The terminal side, "terminal information" of the setting menu → go to the "state of the equipment", it functions to turn ON the "optimization of charging method" is enabled. Build number after the update of SOV32 is "32.1.C.0.328",
TRANSLATED FROM JAPANESE.
