There was no squeaky sound before? Because there is key press vibration even on 4.2.2. You can change it in settings.
Does it sound like a hardware problem or something else?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
I have the same issue and i occured after i updated my phone to 4.2.2 257. So now i have just shut of the vibration touch feedback.. But it still squeaks sometimes when it rings and vibrates. So i belive this is a software glitch but not 100% sure.
Given that this has happened after running a repair that does make it unlikely to be a hardware issue and as such I would advise running a software repair to reload the firmware.
No problem:
To upgrade the phone software
