Is is possible to load stsore cards on to an Experia Phone Model D5503
Judy
Do you mean if it's possible to use a SD-card in your phone? If yes, it is possible to use SD-card.
I meant a store card - eg Myers card - it has its own logo and when you click on it the bar code comes up for the shop to scan. saves carrying all your store cards around. If it CAN be done, then how do you do it please?
This is nothing that comes as default in the phone and nothing that I'm aware of. But perhaps, there is a third party solution or an application that have this possibility. Otherwise, I suggest that you check with the store to see if they have any other option than using the card.
OK will do.
A friend has this application on her phone, but its probablly a different brand.
Well Optus and Telstra could not help. I don't think there is a Sony store near me. I thought the forum would be place to find out.
