unlock bootloader failed / mobile phone won't start up
Guti_Haz
I've tried to unlock the bootloader of my Xperia S. (I did a Reset/Repair via  PC Companion before this)
-> I had some struggles with quite a few apps - after the repair, it was fine again.
For the unlocking I followed the offical steps in developer.sonymobile.com
(steps also described here: forum.xda-developers.com)
But somehow it got stock at step:
fastboot -i 0x0fce oem unlock 0xXXXXXXXXXXXXXXXX
cmd only replies with: <waiting for device>
Since that I can't start up the phone...
I also tried the "FlashTool" (guide lines: www.xperiablog.net)
But when trying to flash in flashmode it says:
11/031/2014 23:31:40 - INFO  - Device connected with USB debugging off
11/031/2014 23:31:40 - INFO  - For 2011 devices line, be sure you are not in MTP mode
So I guess my problem is that my phone isn't in USB debugging mode as it also is shut down and I can't get it started...
Is there any possibility to reset it completely (firmware, bootloader, drivers on my Windows 7 OS, and whatever else is needed...)? Or did I just break it completely?
I don't mind which status it will have (locked or unlocked), I just want the phone to work again Worried_Face
Tags (4)
5 REPLIES 5
Thommo
Use Emma http://developer.sonymobile.com/services/flash-tool/how-to-download-and-install-the-flash-tool/
Be sure to follow the installation instructions or it won't work
Guti_Haz
Thx for your answer,
though also Emma can't "access" my phone (it is not listed)
Since I posted my question on Tuesday I managed twice to start the phone:
1. battery was low - shut down almost immediately 😕
Then I plugged it to the charger for a few hours
->strange: in the first ~30 min the Info Led was on (red), after ~30 min it was off
-> nevertheless I let it load for a few hours (max. 3h)
Reminder: at this moment the mobile is still off.
2. After a couple of tries "Power Button + Volume Up" it started up and the battery was charged at about 40%
-> strange: I tried this over and over and nothing happens, but suddenly it worked.
Unfortunately to reset my phone, it has to be switched off, which I did.
Now I'm in the same situation:
Can't start mobile, it isn't recognized in any programm (Emma, PC Companion - repair function,...)
Also what is quite interesting:
When I plug in the USB cable, the LED is not on any more (I mean not at all - not even at the beginning)
I'm struggeling with this more or less a few weeks now (at first it wasn't that bad)
I also had the situation before, that the LED is not on when USB cable plugged in, though I somehow managed to start it up... (after a couple of tries "Power Button + Volume Up" worked at sometime or another)
summary: phone off, not recognized by any programm, LED not on when USB plugged in 😕
Any suggestions?
ps:
I know I probably should go with a new phone, but I want this to work again since I'm pretty sure it is possible to fix it - just problems with the starting... (when started, it works fine)
Guti_Haz
fyi:
just now I connected the phone again to the wall charger and the LED is back on (red)
-> I'll just leave it for about 2h (until then probably the LED is off again), then I'll try to reset the phone.
I have to play it clever:
I guess after starting, I am not allowed to shut it down again as i it will be unavailable again for the next day or so... (assumption)
Thinking_Face
I have no ideo what is going on in this device...
My next steps:
  1. let it charge for ~2h
  2. disconnect phone
  3. connect the USB to the PC
  4. connect USB to phone (holding Volume down)
  5. try to repair via PC Companion
eather I try it via PC Companion or Emma Flashtool
Wish me luck...
You are free for suggestions 😉
Guti_Haz
Alright, it started again now - took quiet some time...
it was at 0% battery - recharged it to almost 100%
Emma still doesn't recognize my phone.
I tried it via this instruction (Step 2. Boot into Xperia S Recovery Mode Using ADB)
it executed the console, but then the phone had to reboot - same issue -> no reaction then
I removed the battery and atteched some 5V devices to it (intending to drain the battery) and later try again the hard reset.
Then I put the battery back in - did a hard reset -> mobile started up... (I think  it was the first try)
-> not yet sure on what it depends that my phone boots 😕
I think I also have some sh*t together with my drivers, actually I got really confued with this...
Which drivers should be installed?
_
I also had a look at this Sony Mobile FlashTool "Flasher by Androxyde":
I get following logging message when connecting the phone to the PC:
13/015/2014 23:15:18 - INFO  - (MainSWT.java:998) - Connected device : Sony Xperia S
13/015/2014 23:15:18 - INFO  - (MainSWT.java:1005) - Installed version of busybox : N/A
13/015/2014 23:15:18 - INFO  - (MainSWT.java:1006) - Android version : 4.1.2 / kernel version : 3.4.0+1.0.21100-313065-g1ccebb5-00193-gcbc50fc / Build number : 6.2.B.1.96
13/015/2014 23:15:18 - DEBUG - (ProcessBuilderWrapper.java:93) - su not found
13/015/2014 23:15:18 - DEBUG - (MainSWT.java:1028) - Now setting buttons availability - btnRoot
13/015/2014 23:15:18 - DEBUG - (MainSWT.java:1029) - mtmRootzergRush menu
13/015/2014 23:15:18 - DEBUG - (MainSWT.java:1041) - flashBtn button true
13/015/2014 23:15:18 - DEBUG - (MainSWT.java:1045) - Now adding plugins
13/015/2014 23:15:18 - DEBUG - (MainSWT.java:1049) - Stop waiting for device
13/015/2014 23:15:18 - DEBUG - (MainSWT.java:1052) - End of identification
13/015/2014 23:15:18 - ERROR - (MainSWT.java:125) - Drivers need to be installed for connected device.
13/015/2014 23:15:18 - ERROR - (MainSWT.java:126) - You can find them in the drivers folder of Flashtool.
Any ideas?
I'm afraid I can't just reboot my device as it always gets stuck then... Thinking_Face
I've heard there is a possibility to enter recovery mode when the phone is starting (also described here)
Does anybody have experience with that?
I'm done for today, but...
My phone is currently running and I have an alarm clock available the first time this week (tgi Friday), so I got that goin' for me, which is nice...
Guti_Haz
fyi: I wasn't able to solve the issue...
Now the phone is running, but I don't dare to let it shut down... 😕
I also did not install apps which made problems before.
I guess I have to get a new one in the next couple of weeks...
