Update does not complete
FlyingAntZ
G'day,
Been trying to update my Z3 through pc companion for days now. The new lollipop update. Everytime it gets stuck at 'preparing'. Any help would be highly appreciated.
7 REPLIES 7
Thommo
Do you have Java installed and are you running a 64bit system or Win8
FlyingAntZ
Hey Thommo,
Yeah, have java, and running Win7pro 64bit
Thommo
The problem is most likely 64bit which doesn't seem to like the Flashmode driver - Try running PCC in compatibility mode and choose another system or try and use a 32bit system - I'd recommend Windows 7 32bit
FlyingAntZ
Tried compatibility mode and same result.
It's easy to say use another system, yes.
Im just very disappointed that my previous software update worked, and now this one bombs. Totally bummed by it.
Now i have to go and update my phone on some1 elses computer. great.
mr_xzibit
Contributor
You could install another version of Windows on the same pc boot to that for updates.?
Dimaz
Hi All,
I'm running on win 7 32 bit but still have the same problem.
Is ther any solution for this? or i missed a step?
stockyvillage
Contributor
Download xperiafirm and download androxyde flash tool from github.Then flash the lollipop firmware for your device.That flash tool runs in either 32 bit or 64 bit
