usb & micro sim flap
sherif
hey guys i just bought a new z2 and the phone is all good but the flap on the left which covers the usb and mirco sim doesn`t close to the end , it pops up a little bit while the flap on the right can be closed firmly and to the extent that its a little bit down the frame , i saw 2 z2s with my friends today and both have both flaps close like the right flap in my phone
so i want to know does the left flap on my phone which can be closed but still pop up the frame a little bit make it not waterproof? and is it a manufacture fault ?
the phone is all new andn i noticed this thing about the left flap when i got it buy though it was normal
thanks
UPDATE ( two photos added of both flaps )
8 REPLIES 8
dandy63
Leader
Hi, i would strongly advise to head back to where you bought it, speak to the 'expert' in the shop & clearly point out that it is NOT normal.....if you were to use it in water it would leak....so def not waterproof.
Insist on a new Z2....:smileysmileywink:
sherif
sherif
here are two pictures of the 2 flaps , closed to the max
what do you think?
dandy63
Leader
Hi, for some reason i cant see the pictures, just warning triangles Crying_Face
sherif
can i have an idea who deleted my replies? and why? and if he is an authorized person why didn`t he respond to my topic?
dandy63
Leader
Hi Sherif, from the look of your photo it does seem to sit up slightly at the one end......i would still take it back to your place of purchase & talk to the person who said it was normal & ask to compare it with another one
Keep us updated :smileysmileywink:
sherif
I will, thanks
dandy63
Leader
Hi, i've had a Z...Z1 & now Z2 & all of them the flap sits really flush....as you've not had it long & you mentioned it at the time of purchase i'm sure you will have no problem getting an exchange....if the shop insists that it is normal & waterproof ask them to prove it by placing it in a glass of water for 5mins then test it for a bit in the shop Slightly_smiling_Face
Have a friend go with you when you do this......good luck :smileysmileythumbsup:
