Water Resist Alert (Notification) Not Work
manilafortuna
Hello , I have a problem with notifications when cover is open , water warning Not work! Also when the plug charger notifications also not work ... I tought error with Smart Connect and I deleted data's in smart connect , booth still not working ... Then I fix my software with pc companion , I erased to factory settings , That Notifications still not work ! What Can I do?
10 REPLIES 10
profile.country.RO.title
_alexdon_
Strange,I know smart connect holds these notifications.Are you sure you have properly repaired with PCC?
alexdon
manilafortuna
I did it more than repaired , Yes I repaired with PC Companion it was not enought
then I setup new ROM ! Still not working !
_alexdon_
So you have unlocked bootloader?
alexdon
manilafortuna
No !
My telephone status :
Rooting Status : Bootloader Unlock allowed : YES
There just write like that
_alexdon_
In this case,I do not have any idea.You could stop by a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
manilafortuna
should I unlock bootloader?
_alexdon_
No,do not do that.You will lose sony features like X-reality,x-loud etc.
alexdon
manilafortuna
My Bootloader still locked , right? I do not know much about that
_alexdon_
It should be unless you performed the action of unlocking it.
alexdon
